Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-01-2004, 02:09 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
Frankenstein Turbo
Has anyone ever heard of a Frankenstein turbo. Someone was telling me about this thing, a Frankenstein turbo. I guess its like a used turbo you would find at a junk yard then u swap out the internals of a Garrett turbo. It suppose to be a cheap way of having a nice turbo.
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 06-01-2004, 02:12 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: Frankenstein Turbo
would a t3/t4 hybrid be considered a frankenstein?
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-01-2004, 02:34 PM
hotbegel hotbegel is offline
Send a message via AIM to hotbegel
frankenstein turbos refer to the engine, not the turbo.
frankenstein is the nickname for an LS block mated to a b series V-TEC head. in theory, it's good for turbo because you retain the longer gearing of the LS tranny, plus the increased displacement, but the all the perks of V-TEC as well.
in my experience from what i've read and seen, it's a great idea if not an unstable combination. most guys i know of who've tried this have had to rebuild the motors a couple of times, but if you're willing to invest the time and money to build it right, there are a couple of companies, one in CA and one in AZ that build some pretty reliable setups.
that's the basic idea, if you have any other specific questions, let me know.
Old 06-01-2004, 03:14 PM
Yeah i know what you mean, it also refers to the head swap. But this kid has an MX-6
FOR SALE
Old 06-01-2004, 03:44 PM
an mx-6? hm. well i see what you're saying, but i mean, if you found some crap turbo in a junkyard, and replaced all the internals, wouldn't it be better to just keep the housings that the internals came out of? you can pay an arm and a leg for all the pieces inside a turbo, to the point where it'd be cheaper to just go and get a new turbo. you should ask the kid who told you about it what he meant specifically.
Old 06-01-2004, 04:11 PM
I think its a cost issue. Like i dont know if how easy it is to get these parts, but if you got like a re build kit or something for a Garrett GT series and then an older housing, it might be cheaper because i know those GT turbos cost near $2000
FOR SALE
Old 06-02-2004, 04:25 PM
vtec92civic vtec92civic is offline
Send a message via AIM to vtec92civic Send a message via MSN to vtec92civic Send a message via Yahoo to vtec92civic
just buy a new turbo, and there you will have a great looking brand new problem free hair dryer :-p
Gen X Performance
[email protected]
aim:vtec92civic
Custom Turbo Manifolds, IC Piping Kits, Hondata Units, Precision & Garrett Turbos, JRSC's as well.
Rev Hard Stage 2 Turbo Kit Special (Ends June 31st) $2,775 shipped
Drag Gen 3 $2,775 shipped
Old 06-03-2004, 01:01 PM
YellowITR479 YellowITR479 is offline
agrees with vtec92civic...i bought a used turbo and the seal went and i ended up spinning a rod a while back
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
Old 06-03-2004, 04:09 PM
that's the thing is that now days everyone wants to boost, but they all try to do it cheap, and that results in nothing but problems. Yeah I can take $500 a turbo from the junkyard and a bunch of junk parts but:
1. you won't make crap for power
2. you get what you pay for
3. it usualkly results in a bunch of problems.
If you want your car to run properly and treat you well then do the same for it, and do things right the first tim around.
You can find good condition used turbos but it's really hard to tell if the turbo is good until you get it on your car. Someone can easily say yeah the seals are good, and put it on start the car and it leaks oil, and then you are fucked after spending $300 on a t3 turbo now you gota spend another $300 or so to have it rebuilt.
The best things you can do when running turbo is:
1. Get a Good Fuel Setup
2. Get a Decent Manifold
3. Get a good turbo
with those 3 things you'll be golden. get a cheap manifold and the weight of the turbo and heat will crack it.
Gen X Performance
[email protected]
aim:vtec92civic
