Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-01-2004, 06:37 AM
cas4067 cas4067 is offline
96 prelude auto how should it shift???
I don't know if anyone can help me out I just recently bought a 96 prelude and it's an automatic personaly I am stick man so I am not used to an automatic but it seems to me that it shifts a little hard is that normal??? bye the way if anyone is looking for a prelude I am thinking of selling if I get a good offer
Old 06-01-2004, 06:22 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
shifting hard as in grabbing hard? or shifting hard as in the transmission is "clunking"?
Old 06-01-2004, 09:21 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
I have a 92 Si prelude automatic. Typically the shift points when barely tapping the pedal are a notch under 3000 rpms into second. And all under 3000 rpms after that. If you get higher rpms when shifting then could be trans on the way out. When the car shifts I do feel it. Its a tight shift not nessesarilly hard. You will feel the shift though. When accelerating hard the shift should be smoother actually. Check the trans fluid make sure it is a clearish pinkish red color. I had mine changed at 28.000. I have 35,000 on the car now. hopefully this helps.
