Old 06-01-2004, 04:00 AM
mel_carramel's Avatar
mel_carramel mel_carramel is offline
Send a message via MSN to mel_carramel Send a message via Yahoo to mel_carramel
Question Need Help...
Hye guys! i need some help and suggestion.
i've done with my Supra & Skyline R-34 V Spec II. And gladly that i finished the finishing coat early today. It's all dried up now.
But, i just need some help.
1. Do i use rubbing compound before or after Clear Coat?
2. Do i need to Clear Coat to make it shine?
3. Should i rub the body with rubbing compound and then Clear Coat?
4. Do i paint the window border with matt black or just gloss black or Flat black? and when?? before or after rubbing compound?
Paint which i used
Supra is TS-17 Metallic Blue
Italian Red for my GTr-34 V Spec II
Ive inserted some picture for view.
Hope to get reply soon. thanks All~!
this is the container i used to avoid dust
The Supra. Mind the shine.. it is not wax or rub with any compound yet
The Skyline.
Old 06-01-2004, 05:05 AM
Dublinguy's Avatar
Dublinguy Dublinguy is offline
Hi there,
Firstly the Supra looks great in that color but to answer ur questions.
With a metallic colour always clear coat before u use rubbing compound, reason being the tiny little metal flakes will cut the excellent paint job you have done. So clear coat then rubbing compund.
On gloss colors its a preference to whether u clear coat or not. I know Pman never uses clear coat. So if the paint job is done right a rubbing compound will do fine.
I suggest using semigloss black, I personally think the other two are either too dull or to glossy. Also I would say do the surrounds before using the compound. Even if u use a low tack masking tape it can still leave residue behind. So try and do all the painting u need before u compound.
Rafa Benitez -
We won it 5 Times,
We won it 5 Times,
In Istanbul,
We won it 5 Times.
Old 06-01-2004, 06:56 AM
Renegade's Avatar
Renegade Renegade is offline
Send a message via MSN to Renegade
I agree with Dublinguy.
DO NOT polish before clear-coating. I've tried it (just for a test tho' on a scrap styrene) and the clear one just don't sticks on surface.
It's not necessary to ClearCoat a solid non-metallic paint. Just don't rub throught the paint when rubbing and polishing.
For windows, door rubbers and borders use Semi-Gloss black.
For your info check the tutorials on AF
Old 06-01-2004, 07:57 AM
Re: Need Help...
aiight, ill be on semigloss for all the above mention. and ill have to wait for a few days before applying clear as i want it to really dry off. this is my first metallic color usage. i hope it turn out ok.. as a beginner's luck.
Anyway, Thanks Guys... i owe you.. ill post some of my project on progress... thanks again..
Old 06-01-2004, 08:21 AM
Dublinguy's Avatar
Tá failte romhat (You are Welcome)....see u learn more then just modelling on this page...lol
Rafa Benitez -
We won it 5 Times,
We won it 5 Times,
In Istanbul,
We won it 5 Times.
