Old 05-31-2004, 11:41 PM
eclipse2quick21 eclipse2quick21 is offline
resetting your ECU?
how do you do this? thanks in advance
Old 06-01-2004, 12:42 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: resetting your ECU?
push the little red button on the computer....you might not find it at first. you might need a magnifine glass to see it.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 06-01-2004, 12:47 AM
TankMMC's Avatar
TankMMC TankMMC is offline
Disconnect the battery, push the brake, re-connect the battery
shouldnt this be in some other section anyway?
Information is Power.
Old 06-01-2004, 12:52 AM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
wrong section... and just to be helpful all you need to do is reverse the polarity of your battery. i.e. put positive cable on negative post and negative cable on positive post.
shit i'm just kidding i can't be mean DO NOT LISTEN TO ME!!!
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-01-2004, 12:57 AM
Toksin's Avatar
Toksin Toksin is offline
Non-profit Organisation
Send a message via AIM to Toksin
Tank's right. Unplug your battery, turn your lights on, and pump your brake til there is no more current left in your system. If you want to be really proper leave it overnight with the lights on. In the morning reconnect your battery.
Old 06-01-2004, 01:00 AM
Jimster's Avatar
Jimster Jimster is offline
Here for the pussy, man.
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
What he said
Either that or take it out, bash it with a hammer and put it back in. You never know what your car'll do, IT'S LIKE A SURPRISE WITH EVerY BLOW TO THE ECU
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Old 06-01-2004, 01:01 AM
korndogg's Avatar
im tellin u...u just gotta find the red button
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 06-01-2004, 01:58 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
The easiest way is just attach a jumper lead to the positive terminal of your battery and the other end to any exposed metal on the ECU.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 06-01-2004, 02:35 AM
TankMMC's Avatar
Re: Re: resetting your ECU?
Yep. Depends on why you want to reset it though, if you just need to clear the codes, unhooking the "-" and pushing the brake works. (Done this a great many times on my old Cefiro, hoping it would tell me what caused it to randomly stall for no apprent reason - eventually tracked it down by pure trial and error to a tiny oxidized electrical contact).
If you have a flashy ECU which "learns" as you drive and you want to clear the values stored in it then its better to leave it overnight. Unfortunately trheres no "obvious" way to tell if the values have cleared though.
Old 06-01-2004, 09:46 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
disconnecting the battery should work but some cars have a specific way to reset the ECU for vq35 nissans you do this:
http://www.technosquareinc.com/350reset.htm
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 06-01-2004, 01:25 PM
FireBball972's Avatar
FireBball972 FireBball972 is offline
ECU??
wtf??
Badgers, goin to the Rose Bowl this year!!
Old 06-01-2004, 02:09 PM
i figured it out thanks
Old 06-01-2004, 06:44 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Why even bother doing it yourself? Its such a hassle!!
Give me your keys, and i'll do it for you!
Old 06-01-2004, 07:41 PM
Toksin's Avatar
Originally Posted by FireBball972
ECU??
wtf??
Engine Control Unit.
You know, the brains of your car.
(unless it's carbied)
Old 06-01-2004, 07:53 PM
Ssom's Avatar
Ssom Ssom is offline
Send a message via ICQ to Ssom Send a message via AIM to Ssom
Re: Re: Re: resetting your ECU?
shuddup.
