Old 05-31-2004, 09:50 PM
dae dae is offline
new clutch problems on a 95 eclipse
My son has a 95 rs five speed..has a new clutch put in about 3000 miles ago..this car has set for awhile and now their is no pressure on the clutch foot pedal ..we dont have a manual for...does this car have a hyd..clutch??? a reservoir for fluid???..if not..then we have clutch problems.......................thanks for any feedback ..Dae
Old 06-01-2004, 01:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: new clutch problems on a 95 eclipse
Yes, it is hydraulic. If it was a turbo car I could point you right to all the parts, but I'm not as familar with the NTs At any rate, there is a clutch slave somewhere, and odds are you need to bleed the system through its bleeder valve. If this only fixes it temporarily check the slave and master cylinder for leakage, they do fail over time and can lose fluid even while the car sits.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-01-2004, 06:56 AM
joemathews's Avatar
joemathews joemathews is offline
Or just check the clutch pedal assembly...mine had no pedal, and the problem was a loose bolt on rod coming off of the pedal assembly!
1996 Eagle Talon
Old 06-01-2004, 07:31 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
http://www.dsmtuners.com/forums/showthread.php?t=100294
2gnt engine bay tutorial
For Sale 98 Eclipse GS, 5 spd
