Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 05-31-2004, 08:13 PM
salimansari salimansari is offline
Switc between radio and cassette player
I got factory installed Mazda cassette player with radio.
Radio was working fine.
When i put cassette in it and then ejected ,radio is not running.
Actually i dint know how to put it in radio mode,
It wiuld be gr8 if someone can help me
Thanks in advance
Salim
Old 06-13-2004, 04:10 PM
mx6rrr's Avatar
mx6rrr mx6rrr is offline
Re: Switc between radio and cassette player
the factory radio, if its the one I had, has an AM/FM button to the left of the "1." You should be able to push that and it will switch to am/fm....or if that doesnt work, unhook the the negative battery cable for about 30 seconds, of just pull out the radio and unhook the harness from the back (also for about 30 seconds). This will reset the radio and hopefully that will put the am/fm back on (it should switch to fm and be on a low station). If that doesnt work leave the harness/cable off for longer, if that doesnt work it is probley broken....
good luck
