Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-31-2004, 07:07 PM
cws cws is offline
2001 Jeep starting problems
There was one message that I found like my problem, but a little different. When I turn the key it won't start, just sounds like it is going to start. I turn the key the second time it will usually start. sometimes it takes 3 times. Any ideas?
Thanks
Old 06-01-2004, 09:19 AM
chevy406 chevy406 is offline
Re: 2001 Jeep starting problems
check fuel presure
Old 06-01-2004, 02:38 PM
AZFlyingDiver AZFlyingDiver is offline
and fuel filter...
also, make sure your throttle body is clean (you can clean it out real well with carb cleaner) - it it's gunked up, it can be adding to your problem...
good luck!
Old 06-03-2004, 11:16 AM
Myrtle Beach Myrtle Beach is offline
Those jeeps have a lot of problems with the fuel pump losing pressure. Is this problem after the vehichle sits? I have already replaced two fuel pumpson my 99 Jeep grand cherokee- It has 90k on the odometer. It sounds like the problem I was having-Good luck
Old 06-04-2004, 07:52 PM
Schultzy66 Schultzy66 is offline
1997 Fuel Pressure Issue?
I have a 97 GC Laredo which will crank for 5 seconds then turn over, like clockwork, every time I start it. Is this the same problem you had when your fuel pump went bad? I just replaced the Crank Shaft Position sensor, with no results, and am looking into trying the Cam saft sensor. It will start easily if I just ran it. So I am now thinking that I am loosing pressure while it sits. Is it safe to assume my fuel pump is failing and bleeding back into the tank as it sits? Also if i depress the fuel pressure check valve, should gas squirt out when it is not running and has been sitting? I get a little gargle of air and gas thats it. Any help on the matter would be greatly appreciated.
Nate
Old 06-13-2004, 09:17 PM
leowolf leowolf is offline
Re: 1997 Fuel Pressure Issue?
I have been cruising these forums for a while now, there was one post that seems likely to fit your problem and seems likely to me. your oil filter though doing a good job of filtering does not have the required check valve in it.the check valve maintains a positive pressure on the oil sending unit. there is an oil pressure limit switch in the starter circuit, this is just hear say, but it seemed likly to me.
good luck
Old 08-25-2004, 10:33 PM
dude75 dude75 is offline
Nate
I have the exact same problem word for word. Did you find what the problem finally was? Thanks -John
Old 08-26-2004, 10:09 AM
Re: Re: 2001 Jeep starting problems
OK it finally clicked, check the Ignition switch. Try this, once the car is running turn the ignition switch gently within the "on" indent. See if the car stalls. If so the igniton switch may be coming apart or have a dead spot. this happend on one of my mercury's.
Good Luck
Old 08-26-2004, 01:46 PM
Dale Aeppli Dale Aeppli is offline
Nate
HI, HAVE A FUEL PRESSURE CHECK DONE,SOUNDS LIK YOU'RE LOOSING PRESSURE. THE CAMSHAFT SENSOR, IF IT GOES BAD THE JEEP WILL NOT START AT ALL. IF YOU PRESS ON THE TEST VALVE ON FUEL LINE, HOLD A RAG NEAR IT OR YOU'LL GET GAS ALL OVER YOU, IF YOU GET AIR OR VERY LITTLE GAS YOU'RE LOOSING PRESSURE DALE
[email protected]
Old 08-26-2004, 06:30 PM
Re: Re: 1997 Fuel Pressure Issue?
[email protected]
Where is the test valve located. Also, I noticed if I turn the key but don't start it three or four times, the car starts up. This sounds like fuel pressure problem. So should I replace the fuel filter, fuel pressure regulator or the fuel pump or all three. Thanks again for your help. -John
Old 08-26-2004, 07:34 PM
Re: Re: Re: 1997 Fuel Pressure Issue?
HI, YOU WOULD BE BETTER OFF IF YOU CAN HAVE FUEL PRESSURE CHECKED WITH A PRESSURE GAUGE, THEN YOU CAN TELL IF YOU'RE GETTING THE RIGHT PRESSURE AND YOU CAN CHECK TO SEE IF YOU HAVE BLEED OFF AFTER YOU TURN KEY OFF. THE TEST VALVE IS THE STEEL FITTING THAT LOOKS LIKE THE ONE ON A TIRE ONLY STEEL. SHOULD BE ON FUEL RAIL IN FRONT OF THE THROTTLEBODY, USE A RAG AND BE CAREFUL DALE [email protected]
Old 08-26-2004, 07:57 PM
FBATIZ FBATIZ is offline
I would like to replace the crank sensor in my 99 jgc...but I can not find it un the engine..need help.....
Old 08-26-2004, 09:05 PM
HI, IF YOU SEND ME YOUR EMAIL ADDRESS I'LL SEND YOU PICTURE AND INFORMATION ON CHANGING IT. NEED ENGINE SIZE DALE
[email protected]
Old 08-27-2004, 12:19 AM
hundahunta hundahunta is offline
i think there is a tsb for this problem. not sure what years it was though I know is was for a grand cherokee.. the fix was to replace a seal/oring in the fuel pump check valve!!
Old 09-10-2004, 11:51 AM
CU Ballin 803 CU Ballin 803 is offline
Send a message via AIM to CU Ballin 803
My 99 does this too; replacing the fuel pump only worked for a week or two, so I wouldn't try that just yet. From what I've heard, it's a seal problem. The gas leftover in the engine (from the last time it was on) usually helps start it. Because of the leak... the fuel pump has to replace what leaked out, in addition to the normal amount, before it starts... thus, longer cranking time. This is why you only have the problem after it's been off for a while.
I was actually looking to fix this exact problem, so I don't know what works yet. I'll start with the seal/oring in the fuel pump check valve and let you know what works.
Thanks
