Old 05-31-2004, 05:35 PM
pro3racer pro3racer is offline
won't start!
i'm planning on buying my uncles talon, and i called him today about the condition of it. He replaced everything i knew was broke on it(cv joints mainly), and he said he pressure washed the engine, but now it won't start. It started before the wash, after the new parts, and ideas on why it won't start, were're thinking something just got wet.
Old 05-31-2004, 08:00 PM
unciviclized unciviclized is offline
Send a message via MSN to unciviclized
Re: won't start!
of course it's not going to work after pressure washing it. most people don't pressure wash their engine bays. they wash it with degresser and a towel. but if you are lucky like one of my friends, it'll start up and won't rev worth sh*t. But if you ever do get it to start just let it idle for about 20 mins to let everything dry. it worked for my buddy.
Old 05-31-2004, 09:17 PM
okay thanks, could it be a solonoide(sp), or something worse? Possible ideas what it could be?
Old 06-01-2004, 03:20 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: won't start!
any number of diffeferent engine wiring plugs getting knocked loose could make the car not run id start checking all of them
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 06-01-2004, 04:16 PM
okay, i'll pass that along. one of the first things i was going to get for the car was some new performance wires and plugs, and coils, and cap,lol.
Old 06-01-2004, 09:12 PM
FRIMX FRIMX is offline
Re: won't start!
dont forget the alt would have taken a blow too.
Old 06-02-2004, 04:51 AM
MrZ's Avatar
MrZ MrZ is offline
Re: won't start!
pro3racer;
While this has never happened to me, I have read in other posts here that the cam position sensor can be touchy this way. It's the sensor on the side of the valve cover on the passenger side of the car. If it isn't sending a signal to the ECU the plugs won't spark.
Mark
