Old 05-31-2004, 06:31 PM
artheljr artheljr is offline
1988 jeep cherokee cutting out
My 1988 cherokee is cutting out pretty bad. Usually when I back out of the driveway and pull off and when I run it around 55 to 65 mph. Idles fine and runs fine other than cutting out. What should I try first?
Old 06-07-2004, 01:22 AM
scarey1966 scarey1966 is offline
Re: 1988 jeep cherokee cutting out
did you manage to get the cutting out problem sorted? my one does exactly the same thing and I would love to know what the problem is. I have changed the coil, ht leads, etc to no avail
Old 06-07-2004, 08:43 AM
Re: Re: 1988 jeep cherokee cutting out
I thought I had the problem solved...the O2 sensor was unplugged...so I plugged it in and it ran fine for a couple of days. Then started cutting out again. I changed the fuel filter and now im gonna do a tune up and go from there to see if I can weed out the problem. If i figure it out I will be sure to let you know. I may even replace that O2 sensor...there may be a bad connection there.
Old 06-10-2004, 01:06 PM
DrewMrPimp DrewMrPimp is offline
Re: Re: Re: 1988 jeep cherokee cutting out
This happened to me and it ended up being the front o2 sensor. You might want to check your CPS too because that went out on my other jeep and I had similiar problems. Hope this helps.
Old 06-12-2004, 11:58 AM
pdigiacinto pdigiacinto is offline
I agree.. Mine did the same thing and I needed to replace my Crank Position Sensor (CPS).
Old 06-13-2004, 06:36 PM
I believe that will be the next thing I try. Thanks for all of your help.
Old 07-16-2004, 04:28 PM
JULY 19, 2004.....I just got my jeep back from the shop today and I think they may have fixed it. Seems there was a recall some years back and mine didnt get the repair it needed. There are some wires up next to the fire wall that had to be re-soidered and the TPS had to be reset. Wish me luck...hope this solves the problem. Only set me back $175.
Old 07-26-2004, 11:48 PM
mybicepsarehuge mybicepsarehuge is offline
hey man...what about this recall?? explain more...what year jeeps? any specific models such as laredos??
