Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-31-2004, 03:55 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Thumbs down 95 T-Bird, Can't Drive past 105mph??
Ok i know this is cause a limiter or a governor is put on the transmission(so i've read) but whats the real reason behind this. In the real worl i can see why ford would do this, probably cause the average joe dont go over 85-90mph, but it's good to know you have the power to get past 105. Funny when you put the pedal to the metal and it reaches i believe around 105/108 mph, then all the rpm's drop and you just get your acceleration cut off. I've read somewhere, that at the time of production the thunderbirds had stock tires that where not high speed tested tire/so thats the reason they put on the limiter-IS THIS TRUE??
These cars are great though, i mean, as far as a 0-60 car/with work it can be really good. Mainly though, they are more like a 60-100mph car, it takes off like a bullet at high speeds.
PS.. Any of you test drive a lt1 9c1 ex Cop car(caprice) those 95's are shit for 0-60, but man o man 50 and on, WATCH OUT..
Old 05-31-2004, 07:09 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: 95 T-Bird, Can't Drive past 105mph??
103 If I believe and a new chip should handle the problem. The reason I have no idea, but I know how it works. It cuts off half the injectors at a certain speed.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 06-01-2004, 09:11 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
me = reprogrammed chip
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 06-01-2004, 09:29 PM
CamaroSSBoy346 I'm fixing to reburn my chip using a mustang setup wich alows better shifting and no gov.(Oh Ya). Unless you can give a vin # to use in a ford motor co. computer that will do even better in the 4.6?
Old 06-02-2004, 12:35 PM
viperlady007 viperlady007 is offline
They limit the speed due to driveshaft balance and tire limitations. Check your speed rating on your tires. Also you will probably get bad driveline vibration over the production speed limit.
Old 06-02-2004, 04:02 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
More or less what viperlady said. The driveshaft start to oscillate at higher rpms/speeds. If it should decide to let go, you'll quickly learn why there is a driveshaft loop installed on your car from the factory. SC's and Mk's had much better quality shafts used and have no speed limiters. Do yourself a favor, if you reburn your chip to eliminate the governor, get a Mk8 driveshaft in the process.....
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 06-03-2004, 12:02 AM
91_T-Bird_HO_5.0's Avatar
91_T-Bird_HO_5.0 91_T-Bird_HO_5.0 is offline
Send a message via AIM to 91_T-Bird_HO_5.0 Send a message via MSN to 91_T-Bird_HO_5.0
true, i've seen first hand what can happen when a drive shaft breaks and believe me, it's not a pretty sight, i guess i'm lucky though, my car doesn't have a govener on it, i've had my speedo burried before, but that was when i was in my teens, i still crack back on it every now and then, but that's only when a honda needs to be taught a leason
Old 06-26-2004, 11:48 PM
PISFk PISFk is offline
Talking
i love my 93 5.0L no governer and no rev limiter. buried the speedo a few times and taken it up to 6k (redline 5k) with no problems
Old 06-27-2004, 09:45 AM
Arent the first gen MK8 driveshaft composed of 2 pieces?
