Fuel Filter change....
Has anyone changed their fuel filter and is there a pressure relief valve anywhere? thanks
2000 Grand Prix GT w/ gold package. K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe 2004 Chevy Trailblazer EXT Keep on Keeping on... |
Re: Fuel Filter change....
no relief valve except on the motor by the power steering pump. will still be a messy job
what if i pulled the fuse on the fuel pump and ran the van for a couple of minutes to run the lines dry and relieve pressure?
BTW how do you remove the one end of the filter? depress the tabs? i havent messed with that type, the only ones i seen is the screw-on on both ends.
I tried the fuse trick, but I still had some pressure in the line, a good bit of fuel still came out. The filter is very easy to change. Its mounted to the frame with, I believe, a 10 mm bolt and the fuel lines come off by hand, no tools necessary.
