Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-31-2004, 01:13 PM
aurora1319 aurora1319 is offline
over heating
I have a 1998 aurora, and it is overheating when i am driving around , but it won't over heat if it is in park, it will also cool itself down when it is in park, i recently had the thermostat replaced and last week the low coolant light came up so i added fluid like it said and now it over heats does anyone have any ideas on what it could be, thanks!
Old 05-31-2004, 03:24 PM
RoraStar96's Avatar
RoraStar96 RoraStar96 is offline
Send a message via AIM to RoraStar96 Send a message via MSN to RoraStar96 Send a message via Yahoo to RoraStar96
Re: over heating
OK, how hot is it getting?
Have you removed any of the underbody plastic deflectors? That will affect engine temps under driving conditions.
1997 Aurora
"Aurora Snow"
250++HP 4.0L Modified Aurora V8 w/Autobahn Performance
On Deck: RSM intake, RSM 80mm TB
Administrator, www.oldsmobileforums.com
Administrator,Aurora Club of North America
Administrator, www.bonnevilleclub.com
Adminstrator, www.ontariobonnevilleclub.com Coming Soon
Old 05-31-2004, 03:53 PM
it gets to the orange when driving, and it stays normal when in park, i have not removed anything from the car. ??
Old 05-31-2004, 04:53 PM
RoraStar96's Avatar
Re: over heating
O.O wow...ok that shouldn't be happening. If anything, the car goes into "limp home" mode because the cooling system is damn near failing.
Are you showing any SES lights above the dash on the "money bar". Might consider a faulty coolant temp sensor. Get a scan done.
Old 05-31-2004, 07:24 PM
hockeydad hockeydad is offline
Re: over heating
Does the Engine seem to have the amout of Power it should? You may possibly look at plugged Catalytic Convertors. How many miles or KM on it? If your looking at Cats in is going to be expensive!
Sidney
Old 05-31-2004, 10:02 PM
RoraStar96's Avatar
Re: over heating
Ah yes...good call, clogged cat might to that..
Old 06-01-2004, 09:47 AM
scudballs scudballs is offline
Re: Re: over heating
Its also odd that this started happening 'after' you had the thermostat changed. Whoever changed it may have done something wrong. Don't drive it if its overheating. Unless you want a warped head or something. These cars run on the ragged edge of to hot anyway.
Old 06-01-2004, 10:48 AM
RoraStar96's Avatar
Re: over heating
And make sure its a 180T-stat. Thats what the car came stock with, so switching to the more typical 195T-stat may cause issues.
1997 Aurora
"Aurora Snow"
Old 06-01-2004, 12:46 PM
kev's 96 Aurora's Avatar
kev's 96 Aurora kev's 96 Aurora is offline
Send a message via AIM to kev's 96 Aurora Send a message via Yahoo to kev's 96 Aurora
I believe they have to be installed a certain way. The arch over the top of the t-stat has to line up with the housing screws in most cases. Not sure.
Just got a '96 Aurora
89k miles
Mods: Airbox, 20% tint
Very powerful car.
Old 06-04-2004, 03:25 PM
it was a blown head gasget, and they said it would cost about 2,000 to fix, i don't have that kind of money, plus i still owe on a loan on the car does anyone have any suggestions on what to do?
Old 06-04-2004, 09:28 PM
Just changed the water pump, drive pulley, thermostat and tensioner in mine. The water pump is not fun on these, with or without the socket! I would change the head gasket yourself. Won't be an easy task though. Depends on how intimate you want to get with your car!
Old 06-05-2004, 02:22 PM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Who is "they"? I would consider getting a second and maybe even third opinion. If it does turn out to be a blown head gasket I would also recommend doing it yourself if you have a decent car knowledge.
Rob
