Old 05-31-2004, 12:35 PM
sabu sabu is offline
Airbag Light Always On
The airbag light on my '95 Grand Am is always on. I bought the car recently and it came that way. Before getting a diagnostic test I wanted to reset it to make sure it wasn't set off by an external cause like low voltage due to a slipping belt.
Can the light be reset to off? And, are there ways of reading/getting diagnostic codes without plugging a 'puter into the harness?
Thanks for any help.
Old 05-31-2004, 08:05 PM
justin0717 justin0717 is offline
Re: Airbag Light Always On
Disconnecting you battery for like 5 min will erase all codes, and why not just go to autozone or someplace similar and get the codes read for free. Why bother trying to get them yourself when they do it for free?
Old 06-01-2004, 12:57 PM
Grand Am Grand Am is offline
I had the same problem with my light...If its not the air bag or anything here is something u should try: Turn the key to ON, in the fuse box on the drivers side there should be a reset button, press and hold that button until u hear the chimes then release and push it again but dont hold it...Then turn the key off, then start your car...It should be off, it worked for me.
Old 06-05-2004, 08:37 AM
Question Re: Airbag Light Always On
Are you sure there's a reset button on the '95 Grand Am SE? Can't seem to locate it.
Old 06-05-2004, 09:12 AM
nick0750's Avatar
nick0750 nick0750 is offline
if there is a short or bad ground in the air bag system you will never be able to clear the code for more than a day but as long as the light is on you do not have an air bag system be careful.
Old 06-05-2004, 02:03 PM
fluffybunny fluffybunny is offline
Send a message via AIM to fluffybunny
yea no reset button on a 95
Old 06-05-2004, 02:43 PM
Thanks... and thanks.
