Old 05-31-2004, 12:13 PM
lostboy69 lostboy69 is offline
Post brakes
i would like to do a rear disc brake swap can anyone tell me how and where i can get them from thanks
Old 05-31-2004, 06:23 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: brakes
CRX SI or DA teg(NON ABS) is most common swap
Old 05-31-2004, 06:44 PM
Re: brakes
thanks acesnyper
Old 05-31-2004, 06:55 PM
Ace$nyper's Avatar
Banned
Re: brakes
no problem mate! BTW you can use front from civic EX but i'm pretty sure you need to run 14s at least
Old 05-31-2004, 07:47 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: brakes
yes min. 14" rims when doing the ex front brakes
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 05-31-2004, 10:54 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: brakes
http://home.wideopenwest.com/%7Etschmidt/index.htm
Whole setup will run you a little over $120 at a junk yard. You will want to turn the rotors as they will (more likely than not) be rusted. Measure them with a micrometer before buying the rotors, the minimum thickness is stamped on it, if its too thin dont buy them. A new set of back integra rotors will run you about 80 bucks. The calipers will probly be fine from the junk yard but if they are bad new ones will cost you about 100 bucks but will have about an $80 core charge so go ahead and get the junk yard ones to use as a core if they are bad. Its an easy swap.
