Old 05-31-2004, 07:12 AM
94 safari 94 safari is offline
Question 94 Safari Won't Start when hot
I have a 94 GMC Safari with a 4.3 W code fuel injected engine. When cold I can start the van and drive it all over town and it runs fine. The problem is when I turn it off it will not start again until it sits for a minimum of two hours. The van starts right up after that and runs perfectly until you turn it off again and then it will not start for another 2 hours.
The only thing I noticed that was different before this started happening was that the engine temperture was hotter than normal at idle speeds. Any ideas or suggestions would be greatly appreciated. Thanks.
Old 05-08-2005, 10:05 PM
Woodymeister Woodymeister is offline
I have EXACTLY the same problem on my GMC Safari. I was able to test for a spark the last time it happened (3 days ago) and it was not an ignition problem. I was able get it running again by putting a third of a cup of gas into the breather. I suspect its a fuel injector problem but need more advice on this.
Check the reviews for your vehicle on http://autos.msn.com and it will identify the most common issues with it. Fule pumps, fuel injectors and EGR passage are common issues foe GMC Safaris.
