| Let's get Technical! Discussion for hardcore in-depth motor heads! |
b16a into 5th gen civic
After my timing belt snapped I thought it might be a good time to get that motor swap done I've been planning.
I havent bought anything yet and I need to get my car moving again as soon and as cheap as possible with the exception of it not being another d16z6. My car is a 94 civic ex 2 door automatic, I want to change over to a standard but I can get a b series automatic tranny for free so I'm gonna stay automatic for the time being. My questions are... Which b16a will take the least effort to drop into a 94 civic? Will I have to alter/change axles to use a tranny from a b21a1? Will the b16a exaust manifold bolt into and line up with the stock exaust? |
Re: b16a into 5th gen civic
88 Honda CRX Si - B16 90 Honda CRX Si - B20VTEC |
Re: Re: b16a into 5th gen civic
1. 92-95 B16A is the best for you, you don't want to use a OBD 0 B16A(1) because you'll have to change a few things (distributor, injectors, various sensors), and wind up spending the same anyway. This guy has one he is selling (B series auto tranny), good guy too, it's from a 90-91 so the plugs maybe different. http://www.hondaswap.com/forums/inde...0&#entry367147 2. The B21A1 is the old Prelude motor right? Can't use it, not the same B family, plus it's probably a POS anyway. You can either source your own auto tranny, or get a B16A auto from an importer. IMO you'd be better off getting an auto GSR for a little more. 3. Yes it will bolt up, but if you have a model withbthe cat right off the motor, you are going to have a space about 1.5' between it and hte B pipe.
Re: Re: Re: b16a into 5th gen civic
B21a1 is an early '90 something Prelude motor
Re: Re: Re: Re: b16a into 5th gen civic
isn't the b21a1 carbeurated? or is that the years before that one
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Fuel injected y0!!! B20A3 had dual side drafts.
i see.. any idea what the code is for the carb'd lude? it's gotta be pre-87 right? my buddie's got one, it's crazy stuff
ES, and the B20A in Japan, A18A1 (carbed) in the US 87, also EK1, ES1, and EF1 depending on how far back you go.
b21a1 is from the 90-91 prelude si, it is fuel injected
If i get the tranny that was designed for the sir2 b16a I should have no axle problems, correct? I read somewhere that I will have problems with using JDM injectors with my USDM ECU, is this correct? If so what is the best course of action for me to take? |
All i gotta say is...
..stay the hell away from the prelude b-series
I was told that I need axles from an integra and a custom mount for the automatic tranny, is this true?
If you aren't changing from auto to manual, no you don't.
