I have a 95 Jeep Grand Cherokee. I've had it for three years. The transmission was rebuilt after I had it one year (under warranty). When transmission is placed in reverse or drive, the engine stalls and shuts off . If I put the transmission in neutral or park, the engine will restart.
Some people told me it may be the modulator while others said it sounded like major transmission problem. Please help. |
Re: 95 JGC engine stall when transm put in drive
I dont think its your trany, I do think its one of the electronic switches , I had simlar so Im going to check my records and see what mine was
heres a ???, does it jerk at all b4 it stalls, if so, it's your torque converter, if not it may be your idle air control. the reason when ever u put a load on the engine by placing it in gear or turning on A/C or turning the wheel, the IAC is suppose to let it idle a lil higher, and it sounds like it is not doing it. but remember if it jerks and then stalls it is the Torque Converter is locked up.
this sounds like a torque converter to me. the torque converter allows the motor to turn while the transmision is in gear. if the torque converter is locked up, either electericly or mechanicly failed, it will cause this.
good luck |
if the bushings in the front pump(actually in the stator shaft) are worn out you get an internal leak and that can cause the converter clutch to apply.just something ive seen in the past
Re: Re: 95 JGC engine stall when transm put in drive
heres a stupid thought start the car in neutral, push it down a hill, put it in drive, and see if it will run. if the car dies like a stickshift car would if if you left the clutch out.... its the torque converter.. if not have fun pushing the car back up the hill lol dont try this at home lol
