Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 05-30-2004, 06:23 PM
jmichels944 jmichels944 is offline
oil leak
hello, new here...recently bought a 85.5 when i got up the next morning i noticed a small patch of oil on the ground...so i went to have an oil change..they said it was a leak on the rear seal..and got high mileage oil..then the next day there is another patch..so now i have two..why? and how hard/expensive is it to fix? thanks
Old 05-31-2004, 12:38 PM
83-944 83-944 is offline
Re: oil leak
Expense depends, how handy are you with a wrench?
Why? Old seals go bad, was the car sitting for a while before you bought it?
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
Old 06-14-2004, 02:12 PM
pearldrum944's Avatar
pearldrum944 pearldrum944 is offline
Send a message via AIM to pearldrum944
Re: oil leak
Which rear seal, crank, or balance shafts?
'83 arctic silver porsche 944
My gallery.
A better Porsche forum
Old 06-14-2004, 04:29 PM
Re: oil leak
i believe crank...i put some racing oil 30w50..and it seemed to stop the leak..but i don't know if that hurts it or not?
Old 06-14-2004, 05:02 PM
Re: oil leak
no, doesn't hurt. Unless it's very cold where you live.
Old 06-14-2004, 09:33 PM
Re: oil leak
great...just curious...where can i find how the belts are supposed to go..i came today and the AC/alt belt snapped...i bought a new one..but not sure how it goes on..
Old 06-14-2004, 10:35 PM
Re: oil leak
Loosen PS pump adjuster to remove it's belt.
Loosen adjuster on A/C compressor for tensioning.
Install new belt around crank, alternator, and A/C
Reinstall PS belt
Tension both belts using the applicable adjusters (center turnbuckle adjusts length).
If the belts are too tight, you wont be able to wiggle them. If too loose, they'll squeak/wont turn
Good luck.
