Old 05-30-2004, 06:11 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Best Box building material
Im going to build a box from specs given on the Elemental Design website
http://www.edesignaudio.com/im2/boxc...c%20vented.jpg
and my question is, what should I build the box out of? I know particle board is probably best, but even at 1/2" itl be really heavy. should I still go with the 1/2" particle board? or is there a better option?
and also, should I leave the wood bare? or does it matter if I cover it with any kind of carpeting? on my old boxes I used some gray indoor/outdoor carpeting (very thin). Does it matter? or is it better bare?
Old 05-30-2004, 06:38 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Best Box building material
3/4 MDF, stronger than particle board and thicker. That particle board would most likely flex with any decent sub inside which is never good. And carpetting is just cosmetics, you can leave it bare if you want
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-31-2004, 12:42 AM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
you don't want to use 1/2 either MDF or particle board. Particle board will not flex though compared to the same thickness MDF. MDF is a denser material but the major difference is the finish. MDF with cut sand and route smooth...particle will not. Particle board will also break apart where MDF will not. Now if you are really concerned about weight you can make the enclosure out of birch plywood. Price is dbl of MDF...sometimes more but it also about half the weight and denser. There are different trypes of birch and different names. Home Depot calls sand ply and something else. Does not really matter you want to look for a plywood that looks smooth and finished...like indoor wood. You also want as many layers in the wood as you can get.
I build alot of light weight enclosures for guys with "race cars" and I build them out of fiberglass reinforced birch plywood.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
