Old 05-30-2004, 12:19 PM
IIwhitexb0iII's Avatar
IIwhitexb0iII IIwhitexb0iII is offline
Send a message via AIM to IIwhitexb0iII
please help
i just finished installing a pioneer deh-p750mp and when testing a cd player, it will play for like a minute and a half to two minutes until turning off and then turning back on to resume play at that same spot that it stopped. the tuner works fine. i hope that this isn't some internal error, which it seems like, but something that i did wrong, that i could fix. thank you very much for any help in advance.
-michael
Old 05-30-2004, 12:33 PM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Re: please help
Odd problem you have there. Honestly it sounds like an internal problem but there are a few things you can try first. One...did you install any screws put into the radio while installing it? If you did remove them and try playing the CD again. Next check the constant and switched 12v to make sure you do not loose one of those. It would be the switched lead but you can check both for piece of mind. You can also check the ground lead. Also make sure the power plug on the back of the radio is seated properly.
If it only does it on CD and not tuner it is an internal problem. Does not hurt to check first though.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 05-30-2004, 02:55 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: please help
Does it do this at high volume? Low volume? Any volume?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-30-2004, 07:24 PM
any volume really, i know it isn't, but its almost like its overheating. it did it with the tuner today, when i was driving home from work. when i power the system off and then turn the car off, it beeps three times. if you need anything else, please let me know.
-michael
Old 05-31-2004, 01:44 AM
Re: please help
The beep is to let you know that the face is attached to the radio and to remove it. You might be able to turn that off otherwise just ignore....everyone else does..lol. As far as the problem since you say it happens with the tuner you should check your connections and power sources.
Are there any speakers connected to this radio?
2 PG Ti 600.2
1 PG TiDEQ
1 JL 12w6v2
Old 05-31-2004, 11:03 AM
just 4 in the stock locations
