Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-30-2004, 08:41 AM
mrtwo mrtwo is offline
Question Are these jobs too difficult for a newbie?
The only thing i tried is to chang spare tire (95 camry). Now i am wondering if these two jobs too difficult for me?
1. Check rear strut mounts and replace if necessary.
2. Check engine mounts and replace if necessary.
The only tools i have are those came with the car. I don't have a garage so that i have to do it outdoor. If u feel i can diy, what tools i may need? Thanks.
Old 05-30-2004, 12:26 PM
WickedLexus96 WickedLexus96 is offline
Re: Are these jobs too difficult for a newbie?
you will be able to do those but u will need sumthing to hold the engine up when doing the engine mounts and teh struts u will need a jack, jack stands, wrenches, allen wrenches, and a spring compression if needed.
Old 05-30-2004, 04:14 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
You can do it, although you might end up spending more money on tools than you did on parts.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 05-30-2004, 07:22 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Re: Are these jobs too difficult for a newbie?
or than you would have spent on a mechanic.
Old 05-31-2004, 10:45 AM
Good point.
Old 05-31-2004, 01:14 PM
But once u learned how to do it, u know what to do if it gives u trouble later.
Old 05-31-2004, 01:54 PM
Brian R.'s Avatar
Resident Chemist
By the time you have to do this again, you'll have misplaced the tools and forgotten everything you learned from the first time...
Old 05-31-2004, 02:52 PM
That is probably true :-) (how do u put that smile in line with text, Brian??)
But the idea of repair myself really make me excited and i can get some very cheap tools from Ebay, e.g. coil spring compressor. Any idea where to get a torque wrench? Cost about $40 on Ebay.
Old 05-31-2004, 03:25 PM
Brian R.'s Avatar
Resident Chemist
I would recommend against buying a used torque wrench. They are precision instruments and can be damaged or go out of calibration.
Sears has reasonable torque wrenches. You need two, one for smaller bolts and one for larger ones.
Here are the two I would recommend. You can buy one at first if you know you will only need one range, but eventually, you will need both.
http://www.sears.com/sr/javasr/produ...id=00944593000
http://www.sears.com/sr/javasr/produ...id=00944595000
If you are unfamiliar with torque wrenches, these are micrometer torque wrenches. With these you dial in the torque you want and they click and release slightly when you have reached the given torque. Very precise and you don't have to see them to work with them (except to set the torque). KD tools sells higher quality wrenches, but you get what you pay for.
http://www.toolsource.com/ost/result...=torque+wrench
for example, this the wrench I bought:
http://www.toolsource.com/ost/produc...PGL1FCWF668BM8
When you consider the cost of simple hand tools, paying $130 for a torque wrench you will use often is a bargain. The KD wrench is more accurate, and probably has a more precise ratchet (turns less between clicks on the rachet), making it a little more precise and versatile than the Sears' wrench.
Any micrometer torque wrench must be stored between uses with a very low torque setting dialed in. Otherwise the spring inside will loose its tension and the torque will change. Then you will need to get it recalibrated, but you won't know it. Treat them like a precision instrument and they will stay in calibration for a long time.
BTW, rule #1 of torquing, always torque a lubricated bolt into a clean hole.
Also, it is easy to strip the threads on a coil spring compressor, so make sure you know the quality of the compressor before you buy it used. Grease the threads to prevent their damage during use.
Smile is just colon + parentheses or semicolon + parentheses.
Old 05-31-2004, 08:47 PM
Good info, Brian
The 25-250 wrench from sears looks attractive to me. I will go and check it out. What is 3/8 or 1/2 drive? What do i need to work with the wrench? Also where can i get the lubricant used for bolt thread? Thanks.
Old 05-31-2004, 11:23 PM
Snobrdrblinkchik Snobrdrblinkchik is offline
I wouldn't get any of those cheap spring compressors off ebay...go for quality...I've snapped many many many of those compressors I bought off ebay...I don't even mess w/ em anymore...ohh and if you do decide to get coil compressors, it's a pain without air tools...just something to think about
Old 06-01-2004, 12:07 AM
Brian R.'s Avatar
Resident Chemist
Originally Posted by mrtwo
Good info, Brian
The two I picked overlap. If you get a 25-250, you will not have a torque wrench around 20-25 ftlbs - which is a very useful range. The little wrench stops at 250 inlbs which is a little over 20 ftlbs. You have to overlap your wrenches. You probably will never use over 150 ftlbs anyway.
The 3/8 and 1/2" drives refer to the square fitting that fits in sockets. 1/2" is the most you will need. Get adapters so you can use all the sockets with either wrench. Smaller sockets are generally 3/8" drive and larger are 1/2" drive. They go to 1" or larger for big sockets.
Usually engine oil is used to lubricate bolt threads unless they are going into aluminum, then you need antiseize compound.
Old 06-02-2004, 06:55 AM
The Haynes Manual turns out useless when come to details. I try to access the rear strut mount. I was able to pull out rear seat cushion and take off the shoulder bolster bolt. It still won't come off then use my strength and end up damage the plastic clip on the shoulder bolster. (on Figure 20.6, it did not show there is a platic clip on the shoulder bolster at all) Now i can see the top of mounts but have no idea how to take the panel with two speakers on it off. Maybe those are just small things but when u damage something it make u feel bad
Old 06-02-2004, 09:33 PM
Brian R.'s Avatar
Resident Chemist
Look at the bright side, you've learned something already.
Old 06-03-2004, 12:19 AM
Toyrolla's Avatar
Toyrolla Toyrolla is offline
Send a message via AIM to Toyrolla Send a message via Yahoo to Toyrolla
Welcome to Toyota DIY...
Since you're going to be working on your own car, may I suggest a Toyota shop manual for your car. You can probably get one new or used from Ebay a lot cheaper than the dealer.
Good luck with working on your car...
Regards,
Nobody can break it better than me.
88 I4 Slushie, 89 I4 5Sp, 89 V6 5Sp, 82 Corolla, 72 510, 88 Minitruck.
