Old 05-30-2004, 12:34 AM
h2o h2o is offline
alero pump,filter??
2ooo alero 4cyl goes fine for awile then stalls out on the road.if i turn ignition on and off 5 or 6 times it comes back to life. im old school ithink its th filter may be pump. not sure where filter is tank or frame rail?...help
Old 05-31-2004, 11:46 PM
PotIsYourFriend PotIsYourFriend is offline
Re: alero pump,filter??
I have a 2001 v6 and just go under the car and its behind that tank . But watch out when you take it off it is pressurized and will get in your eyes. I know I tried and it burned like a mo fo.
Old 11-08-2004, 09:59 PM
bigbluedaddy bigbluedaddy is offline
Send a message via AIM to bigbluedaddy
check out my thread.
Old 11-09-2004, 01:28 AM
JTrujillo86 JTrujillo86 is offline
The best thing to do to overcome the pressue thing is to start the car and let it get to normal op. temp. Then with the car still running, pull the fuse relay under the hood for the fuel pump. The car will die because it's not getting fuel (this is supposed to happen) and the system won't be pressurized.
Jeremy
