Old 05-29-2004, 10:28 PM
cody911911's Avatar
cody911911 cody911911 is offline
wierd sub action
My bro got 2 lightning audio 10 inch subs and hooked them up to his lightning audio amp....wierd thing is they dont hit together 1 goes up while the other goes down.... It doesn't sound bad but why would it do this?
1st rule of drinking and driving.......you gotta have a beer.....
Old 05-29-2004, 10:37 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
that's an easy one ... you have them wired up out of phase. Take just one of the subs, and take the amp wires off and put them on the opposite connector you pulled them off of.
Old 05-29-2004, 10:43 PM
cody911911's Avatar
Re: wierd sub action
I don't quite understand what you mean by this...are you saying I connected the channels of the amp incorrectly or the wiring got switched at the speaker?
Old 05-29-2004, 11:34 PM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
You have one speaker out of phase from the other. Both speakers have to be in phase with each other to produce bass. What you are doing now is called cancellation. Pull out both subs and verify that the positive and negative wires are connected to the proper terminals.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 05-30-2004, 03:25 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
You have the amp + connected to the + on one speaker and the - on the other, while it should be connected to the + on both speakers. In other words, you have the + and - terminals on one of the subs backwards and you need to switch it (doesn't matter which one, just switch one of them).
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-30-2004, 09:03 AM
cody911911's Avatar
OK that makes sense tahnbks for the help...I was thinking of switching them to backwards would you want the subs to be "cross wired" then or would you want them to be normal still?
Old 05-30-2004, 12:44 PM
Audio Guy
if both subs are backwards ...... you can keep the wired up + to + and - to - .... it won't matter.
Old 05-30-2004, 01:56 PM
sr20de4evr's Avatar
Just as long as the subs are wired the same as each other, that's all that matters
'01 Black Sentra SE
'05 Silver WRX STi
