Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 05-29-2004, 10:57 PM
keithdigio keithdigio is offline
Angry 88 528e instrument problems
I just purchased an 88 528e...the speed and fuel gauge work, as do the indicator lights...the tach, water temp gauge and economy gauge do not work. Also, the ABS light is on, goes off intermittently, and I have an intermittent "check engine" light. Any ideas on where to start debugging this?
Old 05-30-2004, 03:36 PM
TooL TooL is offline
I have an older 528e from 1983 and I am having some slightly similar problems. I have been looking around for a long time to fix my problem, and I came accross one page in particular that I found interesting. They mentioned that if your oil service light gets reset frequently, as well as a few other symtoms, then the battery in the instrument cluster may have gone bad. I dont know if this is actually related or not, but I thought it might be something to look into. Here is the Page if you are interested http://www.bmwe34.net/E28/Repairs/Dashboard.htm . I hope this helps, and I am sorry if a am way off base here.
Old 05-31-2004, 10:15 AM
csieminski csieminski is offline
I had an '86 528e, and had a little trouble with the instrument panel. With the lights on, the light over the tachometer would not come on unless you banged your fist sharply on the top of the instrument panel. Later, the fuel consumption gauge stopped working intermittently. And at one point, the speedometer went completely dead (that turned out to be merely a blown fuse). I also recall that my water temp gauge jumped around or didn't work at all.
First check and make sure all your fuses are OK--also it might be good to clean their contacts of corrosion, just in case that's the issue. Your under-hood fuse box should have a nifty clear plastic cover that indicates what fuses are for what.
If that doesn't solve anything, you may need a new circuit board.
I actually replaced the entire instrument cluster in my car because the odometer stopped working. I got a new (used) one for about $75. I now have a '90 535i, but the old 528e cluster is sitting in my room. If I recall correctly, the speedometer, tachometer and fuel gauge work fine, as do all the indicators (except the oil service indicators, which went on and off at will). Like I said, I think the water temp gauge worked intermittently, as did the fuel consumption indicator. No erroneous warning lights ever came on. And of course the odometer does not work (reads 157485).
The instrument cluster comes in and out of the dash very easily--it's just held in by two screws that go into the underside of the lip above the cluster. You also have the remove the steering wheel (VERY easy unless your car has an air bag--remove the enamel emblem and use a socket wrench to unscrew the big bolt that holds the wheel onto the column). You can surely get a new (used) cluster from e-bay or a junkyard for less than $100. Also, I can ship my old one to you if you just reimburse the shipping cost.
Hope this helps.
