Old 05-29-2004, 09:47 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Oil Pan Gasket
Hey All,
I'm in the process of replacing my oil pan gasket and I have a question. The old
gasket had these little metal rings around the studs attached to the block. I got an OEM gasket and didn't include new rings. Do I reuse the rings (if at all)?
Thanks,
John
Old 05-29-2004, 10:17 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
The 2 oil pan gaskets I've replaced were Honda ones, and I've never seen a metal ring on the gasket, and they still worked great. Maybe the rings on the old one just prevents you from making the bolts too tight.
Old 05-29-2004, 10:45 PM
johnb16a2's Avatar
Re: Oil Pan Gasket
I was thinking the same thing but wanted to check around before I put it together.
Old 05-29-2004, 11:18 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: Oil Pan Gasket
the metal around the oil pan gasket is like he aid so you dont pinch your new gasket...every gasket i get has those metal things around it they come on the rubber ones only.....not sure if they use cork on oil pans
