Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-29-2004, 06:04 PM
matzie matzie is offline
Send a message via Yahoo to matzie
Question 1999 neon timing belt replace
TIMING BELT BROKE ON THE HIGHWAY, TOWED CAR HOME, REPLACED TIMING BELT, CAR WILL NOT START, REMOVED TIMING BELT, TURNED CAN 1 TURN, REPLACED TIMING BELT, STILL WILL NOT START, PLEASE HELP
Old 05-29-2004, 11:26 PM
FuriousMachine95's Avatar
FuriousMachine95 FuriousMachine95 is offline
Send a message via AIM to FuriousMachine95
Re: 1999 neon timing belt replace
when your timing belt broke it probably totally f*^ked up the engine. You will probably have to get a new one or have some serious work done to it.
Acting my age is no fun.....
Old 05-30-2004, 03:43 PM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
when you broke the belt, you probably bent some valves. did you have them checked?
you aint gotta like me, you just mad cause i tell it how it is, and you tell it how it might be
CHECK OUT MY CARS HERE!
drag1320neon and 209neon's babys < 209 neon finished!>
Old 11-11-2004, 05:20 PM
pondod pondod is offline
just wondering if you had an update about your car? Did you get the timing fixed or was your motor shot???
Old 11-11-2004, 06:41 PM
Re: Re: 1999 neon timing belt replace
Thanks for asking, it needs 2 valves, do not know if is worth fixing or not.
Old 11-17-2004, 03:23 PM
austin944 austin944 is offline
Same thing happened to me. Bought new head for 100 on ebay. Head is 420A same one used in eagles and mitsubishis. New timing belt $50 and head gasket $42. Go to www.neonspeed.com. They helped me out! Complete how to is there. Hope this helps.
Old 11-23-2004, 11:33 AM
barretire barretire is offline
Banned
Timing
did you set the timing correct
