Old 05-29-2004, 06:43 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Motor Swap need help pleaseeee
well i threw a rod bearing now that i got it pulled out...i was wondering what other motor could i put in the crx that will pass smog in california...if not does anyone know where i could find a d16a6 motor and tranny good working condition for a fair price????
Old 05-30-2004, 01:44 AM
Re: Motor Swap
any help or what...lol
Old 05-30-2004, 01:50 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Motor Swap
any motor that will pass emmisions will pass it in a crx...
Old 05-30-2004, 01:55 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: Motor Swap
You can put any post year of your car USDM motor in a honda CRX and it will pass smog. The thing is that you have to have it Refereed for the car and year the motor was pulled from. ex. I have a 1995 D16Z6 in my car I have to go down to my local Ref. station have them check the wiring and make sure it is a OBD1 computer running it. Check all smog equipment then after visual is done they then smog it. If it passes then they'll give me a Cal smog legal sticker. From that point on I can get it smogged anywhere but they will test for a 1995 civic ex with a D16Z6. BTW it is cheaper to have the ref smog your car $35 + $8 smog cert. But it can only be done if your doing this or are a gross politer.
This is what my buddys looks like:
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 05-30-2004, 02:57 AM
Re: Motor Swap
my car failed as a gross poluter then passed the nex time around after a few things where fixed...is the D16Z6 a easy to install...also cant i just convert over to a obd1 ecu with a harness kit or i have to redo all the wiring?
Old 05-30-2004, 07:35 PM
Cjz89civic's Avatar
AF Premium User
Re: Motor Swap
The d16z6 is a drop in motor tranny will work and motor mounts will work also. I suggest that you find a Si tranny and get poly inserts for you motor mounts but yes the stock stuff will work. On the wire conversion Im not sure I did mine completely out of a 95 civic ex. If you do it the way I have it done let me know (PM) I will post the site that gives you a step by step in wiring. Expect about 6 hours of wiring.
