Old 05-29-2004, 05:19 PM
cujo92cavz cujo92cavz is offline
92 cav clicked, then started, now just clicking
i just walked inside from looking at my 92 cav z24 v6 3.1L and everythings been fine with it, got home last night, all ok... went to start this afternoon and when i turned the key i just heard clicks and the ABS light flashed on when i turned key, i did that like 10 times, went inside to get me brother and then he stuck key in and it clicked once, the 2ns time it started for him, it ran for 30 seconds then he shut it off, then tried to start it again, now all we get is just clicking noise from the starter maybe, a box with 4 wires comming out of it, no one that knows cars has looked at it yet, just me and my bro.. so if anyone knows whats up or can point my in right direction that would be helpful, but its ok if u dont
Old 05-29-2004, 08:12 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 92 cav clicked, then started, now just clicking
There are several things that could be your problem. First the starter could be going bad. The clicking you hear is the starter solenoid trying to engage the starter but the battery is too weak to turn it over. Second, you could have a dead alternator as well as a dead battery. If it started and then died that could indicate that the alternator is bad as well as the battery. Try putting a new battery in the car or jumping it with another car. If it starts and you disconnect the jumper battery and the car dies, then both your battery and your alternator will need replaced. If it starts and runs then only the battery is bad. Just a few ideas to help you out.
Old 05-30-2004, 03:22 PM
ok well all i did was beat the starter, i hit it numerous times and then tried to start it and it worked, it starts all good now, thats a retarded problem
Old 05-30-2004, 09:00 PM
Three_Fingers Three_Fingers is offline
Look into replacing that starter real soon. When they go bad it'll be all at once.
I have a '93 and mine dropped me cold at a gas station. Shut it off, filled the tank and that was all she wrote. Replaced it the next day. No more trouble.
Old 07-04-2004, 06:26 PM
ok well it went out all together now.. its sitting outside his house.. were gonna have to tow it cause it just keeps clicking when u try to start it and the "beating the shit out of it" method isnt working... anyone know what a new starter costs??
Old 07-04-2004, 06:52 PM
public's Avatar
public public is offline
Under a hundred bucks usually. Check the auto zone web site. they are usually about average on price.
Old 07-04-2004, 11:44 PM
Appleton Appleton is offline
I had a similar problem with my car, turned out to be the park/neutral position switch. Is it automatic? Can you start it in Neutral?
Old 07-06-2004, 02:14 AM
KyleMorgan87 KyleMorgan87 is offline
Send a message via AIM to KyleMorgan87
its either ur battery or u starter wire probly come loose check ur starter wire first and if its caroded or anything take it off and clean it but if it clicks it might b ur battery check ur battery terminals to it might b a loose ground or positive wire on ur battery!!
Old 07-06-2004, 02:17 AM
o yea it might b ur starter sileniod
