Old 05-29-2004, 04:27 PM
jankinnu jankinnu is offline
Send a message via MSN to jankinnu
Chrysler T&C LXi 3.8 A/C and speed control problem
Hello from Finland.
I try to describe my problem with the A/C somehow:
The compressor works fine. I have just inserted freon fluids into the air conditioning system by local A/C maintenance. The problem is that the pressure sensor doesn't work.
Should both or one of the cooling fans start blow when you turn the air conditioning on? My T&C fans blow only when the engine gets warm enough.
How does this pressure sensor work? Is there any other sensors that affect on A/C system?
I have tried to clean all the fuses and relays in the fuse box.
Another problem is with my speed control. It doesn't work. If anyone has good hints where to start fault detection, please tell
Old 06-06-2004, 02:53 AM
Re: Chrysler T&C LXi 3.8 A/C and speed control problem
Cruise is working!
The problem was with the buttons in the steering wheel. Bad connection, needed cleaning only.
Old 06-06-2004, 10:32 PM
I found out that T&C LXi has two condensers. I was under the car and noticed that there's air conditioning refrigerant lines also in the rear part of the car.
I have put too little refrigerant because I didn't know about two condensers. I'll let you know if the A/C starts to work after adding refrigerant.
Old 06-08-2004, 06:27 PM
omer72 omer72 is offline
Send a message via MSN to omer72 Send a message via Yahoo to omer72
cruise control
What did you done? I have the same problem, I tried to look for a fuse for this but no luck.
Can you describe me what have you done to solve this?
