Old 05-29-2004, 02:55 PM
dobbsm3 dobbsm3 is offline
Can't Find Grey Spade Connector on 96' Tahoe
I am trying to hook up the brown wire running on the same circuit as the transfer case for a 26060073 4WD actuator and wiring harness. I am having trouble locating the grey spade connector and do not see a brown wire anywhere near the fuse relay center. The only brown wire I can see is grouped together with other colored wires (blue, purple, green) in some sort of plug connector. I do not see a single brown wire anywhere. Can anyone help?????
Brandon
Old 05-29-2004, 04:51 PM
Jeremy-WI Jeremy-WI is offline
Re: Can't Find Grey Spade Connector on 96' Tahoe
Ok, I have a few pics for you. On my 96 it looks like it was wrapped with black tape, don't know if it was that way from factory or not. On a 98 I found the brown wire was not taped up but the connector was taped to other wires near the fenderwell.
http://www.mhtc.net/~jbomkamp/pic1.jpg
http://www.mhtc.net?~jbomkamp/pic2.jpg
Actually it is on the 4WD fuse and was originally there for an aux battery relay
