Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-29-2004, 02:40 PM
nevermore713 nevermore713 is offline
won't hold water
i have a 93 rodeo 3.2. i recently had my thermostat get stuck and my engine overheated and a hose exploded. i re[placed the hose and thermostat and it runs fine. the only problem is it leaks very badly. it is not coming from the hose or the thermostat. i was told that when water pumps start to go out they will leak out of a vent hole but i can't find it. any help would be appreciated
Old 05-29-2004, 05:39 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: won't hold water
So you can see a puddle under the truck then?
Did you pull the oil stick to see if water is in the oil?
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-30-2004, 10:16 AM
MACH19 MACH19 is offline
if the water is leaking from near the balancer or under the timing belt cover, its probably the pump is bad. wipe everything off real good, then watch for the first signs of a leak to pinpoint its origin.
