Go Back   Automotive Forums Car Chat > Subaru > Legacy / Liberty / Baja
Old 05-29-2004, 01:31 PM
subdude02 subdude02 is offline
Air Filter Question
I own a 1990 Legacy LS sedan and I had a question for everyone. I would like to change my stock pan style air filter, with resenator(sp) box, to a performance cone style filter. My question is that when i took the resenator box off, there was the mesh screen on the hose right infront of the air sensor unit. Would i have to cut off that mesh screen inorder to put on an aftermarket cone style filter, and if i do, would i have to have the ecu tweaked? Any help would be great thanks. My email address is [email protected] if u want to email me.
Old 06-02-2004, 03:29 PM
Aswer
Nevermind, I found out I needed an adapter, I dont have to cut the screen. But i still need to know if anyone knows if Ill have to modify my ECU because of the increased amount of air coming in?
Old 06-02-2004, 10:54 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
you shouldn't need to modify the ECU unless you go forced induction. I would however unhook the battery, pump the brakes (gets free electricity out of the system), and reconnect the battery after a few minutes. This will clear the ECU's memory, and upon the next drive, it will relearn your driving habits and adjust to the extra air. Good luck.
