Old 05-29-2004, 02:30 PM
bigbob bigbob is offline
got boost?
so here is the current plan... 04 mustang... procharger supercharger and intercooler. how much boost can i run untill i need new injectors/ fuel pump/ etc. and after a fuel pump injectors and maybee a new chip how manym ore lbs of boost could i run. stock everything else. any thouhgts on how many pnies or what th ET will be. sorry the question is pretty nonspecific and i no their are a lot of variables but just give me ur guesses. oh and how big of injectors should be out in. i was thinkin a 90lph fuel pump should be big enough.
Old 05-29-2004, 04:51 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
The kit should come w/ new injectors, fuel pump, etc. If not, you could probably run maybe 5 lbs of boost on your stock injectors/pump. Going higher than that and your gonna risk a possability of being way too lean. Whenever you add a power adder there are certain things at the least, that you should upgrade as well. IMO - Injectors, Fuel Pump/Filter, MAF at the least. I'd recommend 30# Injectors, at least a 190lph pump and a 75+mm MAF. Again this is my opinion, any others here?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-29-2004, 04:54 PM
Re: got boost?
i ment 190lph not 90 lol sry typo thanks for the sugestions
Old 05-31-2004, 07:17 PM
eillob's Avatar
eillob eillob is offline
Re: got boost?
I totally agree with you. The only thing I would be concerned with is adding a chip. Most chips are going to advance your timming which is bad when your talking about boost so stay away from off the shelf chips. If after your mods you feel you still need a chip have a custom one burned for your specific application.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
