Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-29-2004, 11:54 AM
DJ Brady DJ Brady is offline
Send a message via AIM to DJ Brady Send a message via Yahoo to DJ Brady
Bleeding Brakes on '90 Prelude
No matter what I do, it seems like I still have spongy brakes. (I plan on getting steel braided lines soon)
Can someone give me a step by step on bleeding the brakes on a '90 Prelude Si?
My plan of action so far has been, furthest wheel from the Master Cyl., press pedal, open line, close line, release pedal, press pedal, open line, close line, release pedal, so on and so forth until I get a strong stream from the line.
Is it normal for the rear squirt to be much weaker than the front? (it seems to be even pressure, so I figure that's okay)
Thanks for the suggestions/advice.
Old 05-29-2004, 05:00 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
You have the right idea. Are you pumping the brake pedal till its stiff before you bleed it? Normaly I pump it 5-10 times. Could be the master cylinder
Old 05-29-2004, 07:17 PM
Re: Bleeding Brakes on '90 Prelude
augh, no, I forgot about the rapid pumping before each 'bleed' to pump the pressure back up..
is it better to do with the car running or off? (something I just thought of)
