Old 05-29-2004, 10:38 AM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
wastegate basics
could somebody explain to me how a wastegate works. and the differences and benifits between external and internal? thanks
Old 05-29-2004, 04:07 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: wastegate basics
Here's a bonus... with this package you will receive Wastegate, Boost controller, AND Blow-off valve FREE OF CHARGE. No purchase necessary. http://racingknowledge.org/topic.asp?TOPIC_ID=117
Old 05-29-2004, 11:13 PM
kjewer1 kjewer1 is offline
AF - Advisor
Man, we're getting our moneys worth for those RKO posts! Good to see.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-30-2004, 07:39 PM
once agian right on.
Old 05-30-2004, 07:51 PM
the reason im wondering is becuase about a weekago my dsm got sick. i was lettin it warm up on a hot day and all of a sudden i heard pressure release from somewhere then my boost gauge dropped to 0. i drove off and after 100 ft or so the needle went back up. (stock gauge). after than terrible experience my car doesnt seem to be as fast as it normally was. i heard my stock turbo spool up but cant really feel it. sometimes when i step on it maby 1out of 10 times it hauls ass but the other times its like im drivin a gs. i think maby my bov is broken(its 2g stock too) and all half of the air its making goes straight threw my bov dump tube. or my wastegate solinode or however you spell it is broke. i made that intercooler leak tester and filled it up at the turbo and it would hold aobut 5 psi then the air would just leave someplace i think about of my intake that feeds the turbo normally but it was off for the tester. if i tried to fill it up to even 10 psi i couldnt because it left threw the dump tube so fast. anyway does this mean my bov is broke or my wg solinode. i have a hayes book and it tells me how to test them but i dont have the tool needed to test them. long story and it sucks but i hope you guys are nice enoguht to read all this shit. thanks - dsmodder
Old 05-30-2004, 08:29 PM
JoeWagon's Avatar
Banned
So you have a boost leak... use some soapy water and figure out where it's at, fix it, and see if it helps.
The stock 2g BOV does leak, so if you want to upgrade once and for all, get a 1g BOV and an adapter, or a hard intercooler pipe with a 1g flange, which is a very good upgrade as well.
Old 05-30-2004, 09:19 PM
the thing is im sellin my gst for a gsx soon so i dont want to put money into it. also its not leakin threw the dump tube or the bov cuz i just tested it agian with tissue paper and its not leakin near them. i think it might be the throttle body but i dont know ill try soapy water tomorrow thanks for the help joe
Old 05-30-2004, 09:48 PM
AF - Advisor
Yes, soapy water is the way to go. But a quick note, real big leaks sometimes dont make bubbles because they blow all the water out of the leak. So feel around everywhere with your hand too. Make sure the compressor youre using is off at the time to you cna hear.
Kevin Jewer
Old 06-04-2004, 09:11 PM
soapy water saved the day. found it at my thorttle body gasket. the first one. im replacing both of them now the front and back one. hopefully thats it but i swear i can hear it around my bov too. i drove a gst cuz i work at a toyota dealership and they got one in and it hauled ass compared to mine. it was stock. the leak is pretty bad i guess and hopfully thats the only one. oh and i stole the bov off the newer gst so its not leakin at my bov. haha
Old 06-04-2004, 09:33 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: wastegate basics
the BOV is another place leaks end up, so it may not be the BOV itself, but a leak in that vicinity... also check your intercooler connections. and the stock 'boost gauge' [if you want to call it that] isn't worth a shit...
Old 06-05-2004, 04:10 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
if it bubbles there is a leak... or like Kevin said.. it might just blow away the water!
Old 06-06-2004, 08:38 PM
where would it leak for the boost gauge. becuase my stock boost gauge is fucked up i think. it never touches any lines. i mean if its idling the pos needle sits like a cm above the second "low" line and when im runnin full throttle it goes like a cm below the second "high" line. im not talkin about the plus or negative lines im talking about the ones before them. could somebody tell me where the boost guage line is at?
Old 06-06-2004, 09:46 PM
AF - Advisor
The stock boost guage is NOT a boost guage. The ECU jsut looks at airflow, makes some estimation, and puts the needle there. Thats why a real boost guage should be everyones first mod.
Kevin Jewer
Old 06-08-2004, 08:19 PM
makes sense. wtf were tehy thinking
Old 06-08-2004, 08:54 PM
it just looks cool... i remember when i first got it i was always stareing at it, making it go up and down... lololol
