Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-29-2004, 07:43 AM
TBmojorisin TBmojorisin is offline
Question G.M. Remote keyless entry Frequency
I have a 1995 astrovan which has an aftermarket remote start installed. This unit works off the factory installed Remote keyless entry module.The problem here is that the factory unit is designed to work from only 30 feet away from the van. I would like to install a range extending antenna to this unit but I need to know what frequency these factory units work with so that I buy the correct antenna.
Old 05-31-2004, 10:50 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: G.M. Remote keyless entry Frequency
You can't do it. The OEM keyless unit doesn't even have a real antenna as it is. When I sell remote starts, I make sure people understand the limitations of using OEM remotes to activate the system. Probably the easiest thing really would be to install a RS with it's own extended reange antenna or atleast a decent aftermarket keyless entry unit.
Old 06-01-2004, 08:24 PM
Re: Re: G.M. Remote keyless entry Frequency
Thanks for the info. I opened the RKE module and found a small bare wire soldered to the printed circuit board. I am going to assume that this is the antenna? I wonder if this could be removed and an aftermarket antenna tuned to recieve the correct frequency installed on the windshield would improve the range??? Any advice is greatly appreciated
