Old 05-29-2004, 01:37 AM
billybob403 billybob403 is offline
how much time should it take for pwr windows from fully down to fully up?
Has anyone experienced their power windows moving slow (in both directions)?
What needs to be done to speed the window up, to comparable to a new car with power windows?
Old 05-31-2004, 03:49 PM
caruch6392 caruch6392 is offline
haha that's a strange question but one night before i shut off my car i remebered your post. my car was at operating temperature and only had teh lights and cd player on. up took about 3 and 1/2 to 4 seconds to go up, down took about 3 (faster that way b/c of gravity ) if they aren't going up that fast just lightly press the accelerator to about 1200 or 1500 rpm to spin up the alternator to get more power. hope that helps
Old 05-31-2004, 10:17 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: how much time should it take for pwr windows from fully down to fully up?
Well the 5 seconds mark is ok. If they are slower than that you can lube the internal mechanism. If after this procedure they are still slow then you should replace the motor
Old 06-03-2004, 09:16 AM
Joelb251 Joelb251 is offline
Send a message via ICQ to Joelb251
The window could be binding in the run channel it sits in also, perhaps shoot a little silicon spray along the window track, that might help a bit.
Old 06-08-2004, 03:06 PM
carnutcass's Avatar
carnutcass carnutcass is offline
Pretty common problem. Remove the door panel and clean the tracks the window slides in. Re-lube with lithium grease. Should help without spending much money.
