Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 05-28-2004, 09:28 PM
Pudnut's Avatar
Pudnut Pudnut is offline
Send a message via AIM to Pudnut
Question Gear Ratio on 1990 Bronco
I'm thinking of putting some 35" tires on my 1990 Ford Bronco Eddie Bauer Edition. So my question is this what is the gear ratio for this vehicle with a tow package. If someone could tell me or even point me to a site where I could find this information, I would be greatful.
Uncase anyone wants to know why I need this information...it's because I would need to recalibrate the stock speedometer and it would help if I had this information for calibrating it.
Old 05-28-2004, 09:36 PM
mjgjr72 mjgjr72 is offline
Re: Gear Ratio on 1990 Bronco
probably 4.10, check metal tag on bolt of rear diff cover
Old 06-08-2004, 02:32 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
you can change the speedo gear also to calibrate it. but to find your current ratio, it will be the first number on the bottom line. it will be like 3 73 for 3.73 gears or 3 l73 for limited slip 3.73 setup.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 06-09-2004, 07:27 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
i thought they had 3.55s
Old 06-17-2004, 06:17 PM
J-Roc J-Roc is offline
I'm leaning towards 3.55s. You'll want to regear your axle ratio to 4.56 or 4.88 depending on what trans you have. C6-4.56 AOD or E40D-4.88s, otherwise you'll be unhappy with the performance...
