Old 05-28-2004, 10:03 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Need Help
I am trying to pull axel but it aint ocming out easy. trying to pull the block with tranny but cant get it out till axels are off.. I unbolted the axels bolts with a 32mm but thats all i know from here...so one can give me some advice getting them off be nice thanks
Old 05-28-2004, 10:15 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Need Help
theres a tool you can buy/rent to do it with. Kinda like a gear puller. If you have an Autozone in your town you can get it from them with a deposit, take it back and you get all your money back.
Old 05-28-2004, 10:16 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
to take out the axkes, you gotta take that 32mm nut off (already done) undo the outer tie rod, and take the nut off the lower ball joint so you can seperate them. The ball joint probly wont just pop off, you will need to hit the hub where the ball joint goes through with a hammer to knock it loose. After those are unbolted, your whole hub will be able to move all around nice and loose. Then you gotta get under the car and stick a screwdriver in between where the axle meets the tranny and wedge it in there so the axle pops out. easy as pie.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-29-2004, 07:15 PM
Re: Need Help
thanks i got it done
Old 05-30-2004, 01:32 AM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
ya some are just hard to get off, old ones
88 civic dx
