Old 05-28-2004, 05:54 PM
cbayne cbayne is offline
Send a message via Yahoo to cbayne
Heat vs. Air conditioning problem
Help. My 95 LaSabre puts out extreme heat on the passenger side and climate controlled air on the drivers, ie. air conditioning works on drivers, but puts out hot air on passenger side. Seems we can never shut off the heat coming out the passenger side but can control the temps on drivers side. Any ideas?
Old 05-29-2004, 10:09 AM
cwrichardjr cwrichardjr is offline
Re: Heat vs. Air conditioning problem
I have the same problem with my '97 LeSabre! A dealer diagnostic ($89) stated "pass. air mix actuator malfunction" I ordered the actuator GM part #16141822 online but now need to know where
and how to install it! Please help.
Old 06-04-2004, 07:21 PM
Found the problem
Problem turned out to be a faulting actuator rod that switches between air conditioning and heat. It is accessed behind the glove box and moves horizontally. The connection needs repaired but at least I can now manually move the rod right or left to get heat or air.
