Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 05-28-2004, 05:43 PM
lukedwag lukedwag is offline
got a knock in the front end when turning
only happens on the turns. sometimes you hear it and sometimes you dont. I checked the front end and all seeemed tight so I then went to the rack and with a helper turning the wheel I came to the conclusion that the rack was shot. changed it and its less nosie but still there. sounds like front end like ball joint or tie rod but with the car jacked up they alll seem tight any ideas ?
Old 06-18-2004, 03:20 PM
jmg0924 jmg0924 is offline
wheel bearing?
My '02 Intrepid was doing that same thing and ended up getting worse. I t ended up being a wheel bearing. You might check it out. I've heard of several people having issues with the front wheel bearings on the Intrepid
Old 04-15-2005, 11:58 AM
wazupguy8142 wazupguy8142 is offline
Re: got a knock in the front end when turning
try checking the wear on your front end bushings, primarily where the control arms meet the front cradle and where the lower control arms meet the tie rods
