Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-28-2004, 04:39 PM
bob47579 bob47579 is offline
replaced head gaskets
almost done, horrible experience, is there a way to rotate engine? someone said you could turn engine to get to rear head by loosening motor mounts and then turning some how? my friend did the work, he is barely speaking to me.
Old 05-28-2004, 07:27 PM
jim56's Avatar
jim56 jim56 is offline
How bad was it? how long did it take?
Old 05-29-2004, 08:09 AM
Re: replaced head gaskets
it took 30 hr, it is only rated to take 21 by a garage, do u know how to rotate engine forward?
Old 06-01-2004, 01:53 PM
Angels_Aurora's Avatar
Angels_Aurora Angels_Aurora is offline
How Did You Know?
I suspect that I have a blown head gasket. My car overheats after driving it short distances. How did you know for sure that your car needed the gaskets replaced?
Old 06-02-2004, 09:19 AM
Re: How Did You Know?
pressure test
Old 06-02-2004, 09:20 AM
pressure test
Old 06-02-2004, 02:55 PM
Pressure Test
Is the pressure test something you can do yourself, or do you have to take it to a mechanic?
Some People Just Don't Know How To Drive...
I Call These People "Everybody But Me."
Old 10-23-2004, 02:56 PM
avatar307's Avatar
avatar307 avatar307 is offline
Depending on what you're pressure testing, you can usually do it yourself. Though many times it will require a special adaptor and an air compressor. Other times, just a gauge. At any rate, you'll need a service manual to look up the pressures and attachment locations.
If your car is over heating after short distances, my first guess wouldn't be head gaskets. You should be loosing anti-freeze (and oil)... head gaskets are one of those things you should never have to replace. (My opinion, by the time they go, you should probably just buy a new car because everything else is worn out too. LOL)
ANYWAY - My first guess would be a cooling system problem, as follows:
1) Coolant level
2) Replace thermostat. $5 + 1 hour
3) Fans and fan relays
If you think your head gaskets are blown, you should have anti-freeze in your engine oil.
Old 12-15-2004, 09:24 PM
shadytree shadytree is offline
Re: Re: replaced head gaskets
Head gaskets can fail in several ways. To detect water in oil, simply take the dip stick out and drop a drop of oil on the exhaust. Oil with no water will just smoke. Oil with water will sizzle. As for the compression test, use a compression gauge and adapter screwed into spark plug hole. All cylinder pressures should match each other. If one cylinder pressure is low, squirt 30W oil into suspect cylinder to 'seal' rings. Low pressure can be a result of blown head gasket or valves at this point.
Old 09-14-2005, 06:50 AM
Aurora95 Aurora95 is offline
Re: Re: Re: replaced head gaskets
YOU DONT CHANGE THE HEAD GASKETS ON THIS ENGINE THE TIME AND LABOR YOU WOULD SPEND ON DOING THAT IT WOULD BE CHEAPER AND FASTER TO BUY A USED ENGINE AND PUT IT IN. SAVE YOUR SELF THE HEADACH UNLESS YOU ARE AN CADALLIAC TECHNICIAN
