Old 05-28-2004, 04:48 PM
spinner074 spinner074 is offline
Question trunk air presure
I have subs in my trunk with 6x9's on the rear deck....When I turn on the subs the 6x9's get sounding funny from the air presure in the trunk...What can I put around those 6x9's to keep them from moving from the subs presure??
Old 05-28-2004, 06:45 PM
AZFlyingDiver AZFlyingDiver is offline
Re: trunk air presure
If you haven't Dynamat'd the under the speakers - try that... and maybe stuffing some poly-fil behind the baskets...
Old 05-28-2004, 08:46 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
There isn't much you can do, other than build solid boxes for the speakers that hang below the rear deck. Strengthening the baffle won't do a thing, the pressure is moving the cone itself, not the baffle that the speaker is mounted on.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 06-01-2004, 10:01 PM
GCguy2169 GCguy2169 is offline
Send a message via AIM to GCguy2169
You can actually buy baffles that are pretty solid and place them on the bastket of the speaker, saying that the 6x9's are not already in baffles, (most arent)
Coming soon..RE XXX 18'', Hifonics Brutus Amp..Any comments on these products please respond in any thread of mine.
Old 06-02-2004, 07:50 AM
sr20de4evr's Avatar
You still run into the problems I listed
If the baffle is not COMPLETELY air tight against the rear deck, then it would serve no purpose
If the baffle is completely air tight, then you cut all the low frequency extension and efficiency of the speaker
'01 Black Sentra SE
'05 Silver WRX STi
