Old 05-28-2004, 02:44 PM
jimmy[the]gent's Avatar
jimmy[the]gent jimmy[the]gent is offline
Angry all bolts on my exhaust are seized.....
its and 89 toyota tercel n i tryed to get exhaust manifold off and i broke two bolts theyr rusted theres only three bolts on my exhaust manifold and i got scared after breaking two so i walked away ......any way i can get that last bolt off w/t breaking it ??
Old 05-28-2004, 03:47 PM
mjgjr72 mjgjr72 is offline
Re: all bolts on my exhaust are seized.....
if they are studs with nuts (which i think they are)you can heat the nut with a torch.
if they are bolts you will probably have to snap the rest off and hope only the top brakes off , heat the manifold flange, or torch off the head of the bolt
once you snap of remove the rest, hopefully they didn't snap flush with the manifold.
if there is some stud sticking out you can grab it with vise gripps and twist it out or get a stud remover you will probably have to heat the manifold flange to get them out.
if they are flush with the manifold flange you will have to drill and try some easy outs or drill and tap.
if you are lucky and get them all out you should run a tap in the holes to clean up the threads and blow out the shavings before putting in new studs.
good luck i'll keep my fingers crossed for you.
Old 05-28-2004, 10:45 PM
thanks allot for reply i think im just gonna buy an easy out kit because i dont have access to a to torch and im scered of them :/ and some one said if i get to put bolts back in the manifold to use anit seize cream so problem dosnt happen gain ....
Old 07-15-2012, 02:15 PM
Jim Geo7 Jim Geo7 is offline
Heat the bolt/nut with a torch (propane is great). Make it good and hot then spray a good wash of lube, WD40 works pretty good, over the hot nut or bolt to cool it down. If you've ever soldered copper pipe together then you know that the melted solder wicks up the pipe joint. In essence that's what's happening here with the penetrating oil. It doesn't always break the rust weld but it often helps a lot.
Old 07-15-2012, 02:46 PM
danielsatur danielsatur is offline
It's probably best to break loose exhaust manifold bolts with the engine hot, and take out when cool.
Like braking loose lug nuts before jacking up car.
Caution - Very hot, and use gloves.
Old 07-16-2012, 09:13 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
People, this thread is waaaaay old. I'm sure this guy hasn't been driving around for 8 years with two snapped off exhaust bolts waiting for your answer. While your answers may be relevant, they are not timely. In the future, please consider this before responding. Thanks.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-16-2012, 10:42 AM
The last time we had that kinda problem is with a cast iron head.
It's probably best to remove the header pipe at the exhaust manifold, before Head or engine removal.
1) Once the head is off, use liquid wrench + impact tool for an easy removal.
Old 07-25-2012, 01:57 PM
If the bolt breaks off into the head, weld a flat washer onto the stud, weld a nut onto the washer, and try again.
This is an old Thread, but we got 2-bolts broken in a thermostat housing.
We might just drill out the bolts + use new stainless steel lock nuts + bolts for replacement.
