Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 01-19-2002, 10:12 PM
Supa_chink Supa_chink is offline
Send a message via AIM to Supa_chink
Engine bearings
I drive a 91 g20 auto. It seems that whenever there is a gear change, my engine slams into my frame causing a great deal of jolt to me and my passengers. I took it to a mechanic, and he told me that it was the engine bearings. I have established that its not my tranny, but it could be my shocks as well. I would just like to inquire if anyone knows where to get some engine bearings for my car.
Old 01-20-2002, 01:22 AM
NA Racer NA Racer is offline
Engine bearings? Which ones? Sounds like it may be engine mounts, my car did the same(manual though) when the engine was under load it was fine, lift the right foot and a clunk or series of clunks followed! I though drivetrain but was engine mounts. They are easy to check, can do visually, make sure they are not squashed looking! Front left( looking towards car, under bonnet), botom-middle of engine to chasis rail and one near tranny I think....from memory
"I have only one request....
give the honda no respect"
Old 01-20-2002, 03:21 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
On the Auto there are three mounts. One is on the upper pass side, the engine front mount. The next is the trans mount (which may have gone) in your case...this is on the bottom drivers side basically almost in the middle of the engine compartment. Then in the rear there is a back engine mount...this one from my experiences never was bad.
Also, what may be happening is that your trans may be going. The trans that hooked up to the G has some problems where material was getting chunked off from the insides and torque converter. There are screens (filters) inside the trans that catch this material. Becuase there is material blocking, you may not be getting the correct pressure to the trans and therefore it is creating a harsh shift.
Besides physically checking the eng mounts, I would also try and rev the engine and see how much it moves around. If you hear it bang against the stops, you're in need for new mounts...actaully if you have never changed your mounts before and you have a 91 you should probably do it anyways.
-Brian Jones
I got a snake man
Old 01-20-2002, 10:48 PM
Thanks about all the info, but could someone help me find these parts or let me know where to buy them.
Old 01-20-2002, 11:47 PM
Well...you need to determine what you want to get first...more impotantly, what needs to be fixed.
-Brian Jones
I got a snake man
Old 01-21-2002, 05:47 AM
I was referring to the engine mounts, since you told me that i should switch them out since I AM driving a 91...:sun:
Old 01-21-2002, 06:16 AM
Ok well changing them out yourself is kind of a tough process, as you need to kind of knowing what you are doing. So you would need experience, tools, a FSM and a helper.
I would say take it to a good nissan/infiniti dealer and have them do it. They may charge alot, yes but they do warranty the work and the parts and its the best way to go if you dont have all of the above resources.
-Brian Jones
I got a snake man
Old 01-22-2002, 11:47 PM
Good advice, and as my Dad always said
'if ya don't know what it is or what it does, don't touch it!'
Old 01-23-2002, 08:51 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Ahh phooy. You'll never learn anything that way. The best way to learn about something is to break it. The more expensive it is the better you learn.
Old 01-23-2002, 11:52 AM
Cue-Ball's Avatar
Cue-Ball Cue-Ball is offline
LOL! That's a good way to look at things! I'm glad i did most of my "learning" on my cheap old Mustang. Lots of parts, cheaply available.
1999 Infiniti G20t
17" RH Evolution M7000's with Toyo's
Mostly stock...for now.
Klaatu Varata Niktu
Old 01-23-2002, 09:39 PM
OK then, you have far to much money and more than one car!!!!
