Old 05-28-2004, 12:06 PM
SlowerCivic SlowerCivic is offline
Boost Gauge??
Ok I have a boost gauge but im clueless to were I hook up the vacumn line to the engine it comes with engine adapters but im not sure were to put it
Old 05-30-2004, 12:20 AM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
Well first of all you need a turbo or supercharger to provide you with some boost.......
Old 05-30-2004, 12:47 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
your gonna have to "T" or tap into a vacuum line from the engine. when i hooked up my vacuum gauge, i tapped into the Fuel Pressure Regulator (FPR) vacuum line. if you dont know where your fuel pressure regulator is, 1st find where your fuel rail is? (I hope you know where this or what this is). look to the right of the fuel rail and you should see the FPR all the way at the end of the fuel rail. there is a vacuum line that runs to the FPR. its the hose on the TOP of the FPR not the BOTTOM one. the bottom is a fuel line. cut in the middle of this line and connect one of the "T" fittings that came with your boost gauge to the line you just cut. then connect the hose for the boost gauge to the T connector. then your done. hope this helps
see if this link works. it has a picture to guide you
http://www.automotiveforums.com/vbul...+gauge+install
in the bottom right of this picture, you will see the FPR and the vacuum line on top of it.
oh yea, i hope you have a turbo/supercharger. you wont get any boost readings from your gauge if you dont have one. if your gauge measures both boost and vacuum then you will only see the vacuum readings if ur car is not forced induction
www.MEDIUMRACING.com
Old 05-30-2004, 01:54 PM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
Re: Boost Gauge??
oh god i hope he does
Old 05-30-2004, 02:43 PM
E Honda's Avatar
Re: Re: Boost Gauge??
Hard to tell by his screen name thats for sure........
Old 05-30-2004, 02:55 PM
Beastiek2's Avatar
Banned
Re: Re: Re: Boost Gauge??
excellent point!
