Old 05-28-2004, 11:05 AM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
Power Loss at 5000rpm
I dont know if this holds true to all Lt1's, But ive noticed that my power is down between 5000-6000 and then when it shifts, I get slammed back into my seat, it seems my powerband is 3000-4500. Could a mild cam and heads change that? or could reprogramming my shift points to 5250 or 5000 bring my power back for the next gear (not litterally power back but make it so my engine runs in the power band for a little longer)
Old 05-28-2004, 11:39 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
3000-4500 is is probly where your peak power is. the length of your stroke and camshaft duration would probly effect your power band more than anything. I wouldn't really recommend shifting at 5-6000 rpm, atleast not on a stock Lt1
Old 05-28-2004, 06:32 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Power Loss at 5000rpm
yup, TPI's are worse, cuz they have longer runners, LT1 is better, but sill uses cross routed runners that are quite long, putting the power curve low in the rpm band.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-28-2004, 08:56 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
putting a hotter cam would move your powerband up, but possible sacrifice low end power. the lt1 comes stock w/ a relatively mild cam. you could get a good reliable comp cam grind w/ a little more lift and duration than stock, probably solve the lack of high end power.
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 05-28-2004, 11:35 PM
4onFloor's Avatar
for small blocks i like a cam with about .442-.488 lift and about 260deg duration. it gives nice low end power but holds it clear to the mid upper rpm's.
