Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 05-28-2004, 11:01 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
HELP!!! engine hesitates at WOT
hey whats up. My friends 88 RX-7 has given him alot of problems. this is the scenerio:
when he steps on the gas all the way (WOT) the car will go up to 4K RPM then it will hit a wall. it wont go past 4000 rpms. it's like he has a rev limiter at 4K. But if her were to slowly take the rpms up (Not flooring the car) he would be able to get past the 4000 rpms with no problem.
whats the problem with his car? could it be a bad TPS sensor? thats what we think it is
www.MEDIUMRACING.com
Old 05-28-2004, 01:22 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Re: HELP!!! engine hesitates at WOT
The dreaded 3800RPM hesitation. Bad engine grounds and/or stuck 5/6 port actuators.
Old 05-28-2004, 02:07 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
If it hits a wall. Then one (or both) of his secondary injectors are not firing. Reason that he can gradually accelerate past 3800 is the fact that the pressure sensor is not sending a signal to the ECU to fire the secondary injection system (low engine load).
Is it a TII or an N/A?
1988 10th AE Edition TII
More mods then you have.
Old 05-28-2004, 10:22 PM
it's the NON turbo II and it has two injectors. how would we go about fixing the injector problem. now which pressure sensor is that? the MAP sensor? could it be a bad MAP? or should we put in some new injectors?
we replaced the ECU, Mass air flow sensor, several TPS sensors, fuel filter and put in a new ported throttle body, but the problem hasnt gone away.
any help will be appreciated. and how do we check the actuators?
Old 05-29-2004, 01:04 PM
J-Rat's Avatar
LOL!!! Umm it has 4 injectors man. You cant see the other 2 because they are under the UIM. You need to check the connectors on the 2 injectors that you CAN see. Another thing. Unplug the pressure sensor (its on the passenger fender side in the engine bay). Report back!
Old 05-29-2004, 08:58 PM
JTYnBJD4Ever JTYnBJD4Ever is offline
Send a message via ICQ to JTYnBJD4Ever Send a message via AIM to JTYnBJD4Ever Send a message via MSN to JTYnBJD4Ever Send a message via Yahoo to JTYnBJD4Ever
Re: Re: HELP!!! engine hesitates at WOT
My car is doing the same thing, but then once i slowly went up in the revs, my entire car wont start... can you give me a direction to go and what I should do. Thanks guys
Old 05-29-2004, 11:19 PM
lol. my bad. i didnt know it had 4 injectors.... i only see two of them so thats why i said that. im not too good with knowledge on these rotary's =/
oki, so this is what we should do:
-unplug the MAP sensor. do we unplug it and run the car w/o the map sensor???? will the car run if we do this man?
-check the 2 injectors that we do SEE on the intake manifold in order to see if they are connected properly. To check the other two injectors, we're going to have the remove the UIM. the UIM is the intake manifold right... just check n.
his problem is probably fuel related because his A/F ratio gauge never reads rich when he floors it. it's always lean or sometimes get to the stoich position.
oki we will try it tomorrow and i'll tell you how it goes...
p.s. you guys dont thinks it's a bad TPS sensor right? cuz thats what my friend thinks it is.
Old 05-30-2004, 03:29 AM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
I use to have the same problem , It just hit a wall at WOT at 4k . The problem was #1 secondary injector. now fixed , a week went by ,now it Hesitates at WOT at diferent Rpms . Do you guys think the remplaced injector is messing up again or it might be another one of the other 3??
P.S sorry for stealling Tread , I din't want to make another tread about a similar problem.
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
