| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Yep, again me, with the same questions.
The reality goes like this; I have tried two different methods with painting the model: First one: Using DupliColor; primer, color coat and 20 minutes after color coat I clear coated the car. Result: Very minor cracks in the paint (cracking in the panel line). Second one Using DupliColor; primer (drying 24h), color coat (drying 4-5 days) and final clear coat. Result: Some major cracks in the paint (cracking in the panel lines). Now I had enough of this trouble! I have ordered Tamiya's TS Primer, TS colors and TS clear coats. But before I start to spray my next model I want to know how long to wait before clearcoating solid paint with Tamiya's TS ClearCoat Some say, when using tamiya TS clear, that solid color should dry for about a month? Is this true?And another thing; I'm also thinking of clearcoating the solid (lacquer) paint with Testors (or tamiya) GLOSS clear coat in bottles. Explanation: I'm asking these questions becouse clear coat have ruin two of my models by now. And with my 300ZX I would really like to do a perfect job and go on local Scale Model contest. Thank you! |
Re: When to Clear Coat?
Maybe you should look at http://italianhorses.net/ There is a great tutorial for painting your cars with Tamiya paint. I can also tell you the way I work: Gray primer, white primer. Wait a couple of hours, sand it lightly. Mistcoat of color, thicker layer of coat so you don't see any primer. Let the body dry for 3 to 4 hours and after that clearcoat. If necessary, clearcoating twice directly after eachother is possible also.
Good luck.
I did read and printed all the tutorials. It works great until clear coating.
I got a lot of painting tutorials but no either one of them covers how or when to lay down a lacquer clear coat.
Bas: is this for Tamiya colors you´re talking?
The Tamiya sprays are awesome if applied correctly. The clear should be applied within 10-15 minutes of the last color coat or wait 3-4 weeks for color to totally cure to avoid cracking. I use Duplicolor paints too and have never had problems. Could be the primer was not totally cured. I would let the primer cure at least 2-3 days before shooting the color and clear coats. Even with Duplicolor, I apply the clear coat immediately after the last color coats. If you use a food dehydrator to cure your paints you can change the rules. HTH, Marc
Completed Pro Touring Projects ![]() ...the pro touring experts
Thanks! Thats what i needed!! I didnt know that the clearcoat must be applied so soon or wait 4 weeks.
This was really helpful!
Okiemodelbuilder:
Thank you! Now I got all my problems solved! Could this please go into FAQ. It took me two models to get the answer. Thanks! |
If you have already ruin 2 paint jobs i wouldnt bother using it.
Most here know i'm not a fan of clear coats. Spend the time on getting a good paint job first, use some compound to bring out a good gloss then wax it to get a good finish. Clears just dont look real IMO
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
@Primera Man: Hmm, I noticed that you don't use clear's. And your paint jobs are just awesome.
A little experiance of mine; I got REALLY gloss and shiny surface after clear coating the mica black. Metallic color itself doesn't give so much shine and I'm mostly using metallic ones. Oh, waxing - I'm using Sonax Automotive wax. That yellow solid stuff. Should I think of getting Tamiya liquid state wax? Is there a difference? |
All Tamiya metallics, micas and pearls need a clear coat. If Duplicolor paint has (CC) after the color it needs clear coat too. Most solid colors do not require a clear coat. It is a matter of personal preference.
Marc Quote:
