Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-28-2004, 04:58 AM
michellebme4u michellebme4u is offline
Send a message via AIM to michellebme4u Send a message via Yahoo to michellebme4u
Angry No Fire
I Have A 1993 Dodge Dakota Automatic 6cyl. The Battery Is Good, It Is Turning Over But It Is Getting No Fire. Any Ideals On What Might Be Wrong With It?
Old 05-28-2004, 10:26 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: No Fire
What's going on? Did you shut it off and now it won't start again, or did it stall out and now it won't start? What exactly happened? It could be many things, but we can narrow that down with some more information...
Old 05-29-2004, 07:55 AM
Re: No Fire
Just went out one day and it wouldnt start.
Old 05-29-2004, 12:18 PM
BleedDodge's Avatar
Re: No Fire
Could be many things.
The fuel pump is shot.
The distributor power wire fell off at the coil or the distributor.
Bad crank position sensor.
Plugged/plugging catalytic converter.
No gas in the tank.
Clogged fuel filter.
Is your check engine light on by any chance?
Old 05-30-2004, 06:24 AM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: No Fire
Here, I'll add a little more to bleed's list:
Throttle position sensor
No power to ECM (no light in dash either)
Engine harness loose/ bulhead connector loose
fuel pump relay
One of these ought to get you going again.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 05-31-2004, 09:37 PM
BleedDodge's Avatar
Re: No Fire
How about previous problems? Perhaps there was something going wrong that led up to this happening.
Did you have any work done to this truck before? If it had a previous owner, do you know of any work they performed, or had performed on the truck?
Old 06-01-2004, 06:25 AM
emeans emeans is offline
I had the same situation on my 93 V8 Dakota and it turned out to be the crank sensor.
